MAP Sensor info?
grnchevyz
453
27
May 3, 2006
Cornwall, Ontario_Canada
Picked up what is supposedly 3bar GM MAP sensor.
No part # on the unit, GM stamp on top and it is stamped with
103 7270
From what I gather, 7270 means either 1997 or 1987 270th day.
103 I can't find in any listing for map sensor stamps.
1 Bar: 039, 460, 883, 876
2 Bar: 886, 012, 539, 609, 701
3 Bar: 749, 861
Is all I could find...
Anybody have insight on this?
It is installed using the stock MDP wiring, sensor left unplugged. Reads 9-10psi at idle and pegs at 30psi by 1psi of actual boost.
It almost seems like its just an MDP sensor.
Here's the log.
  • log.2009.06.08-01.elg
If its pegging full before 1psi, then its most likely a "1Bar" as said
bling5tatus, wiring up a MAP for tuning purposes with DSMLink using the MDP wiring. I should have specified....
It IS a 1bar confirmed by Dave at Link.
The Evo X has a 3 bar MAP sensor thats fits the MDP spot perfect. Same harness I think also. Thats what a lot of the Evo guys are using to log boost.
They are a little pricey though, since they are a dealer item.
Sorry for the bad info, the EvoX MAPs are 3 bar.
You can get OmniPower MAPs the fit the MDP hole. In 4bar.
Do NOT pay high price for Omni Power MAP sensors... they are Motorola MAPS ($6-$12) in a plastic case... they are making well over 1000% profit on the gomers that buy these.
Look at freescale.com... that's the maps that omni repackages and marks up.,
