a91eagletalon
Supporting Member
- 278
- 13
- Aug 24, 2005
Norfolk,
Nebraska
I need help identifying these 3 gear sets. Gear set A I know is out of a 92 transmission i believe. Gear set B I think is from a 91 not sure. Gear set C I believe it's from a 91 but I'm not sure about that either. Can someone help me identify these gear sets I'm not sure what all the groove marks mean and how they're supposed to match up. I am trying to replace the A set of gears.
Possibly the gear set cluster on the intermediate shaft on set B and C could be switched around. As in pressed of the C shaft and put on the B shaft. I hope this is not to confusing. Ask any questions I'll will get right back with you.
Gears set A
Gear set B
Gear set C
Gears set A
Gear set B
Gear set C
