Gino
- 0
- Feb 18, 2004
rotterdam,
Europe
Hello,
I recently bought a 1990 gsx,with a dead clutch, so I took it, drove it home
(5 miles) real slow, it was slipping like hell, but it felt strange, never had e slipping
clutcg like that before, anyways, I bought a new clutch, put it in, and the damn thing just
kept slipping. Put it in first, second... all gears, just keeps slipping, and as I saw my
speedometer going up while the car being still, I knew there was something WRONG with my trans.
So I took it apart to get the Center diff out. And here is my problem,
it just WON'T come out. As far as I know, it should just be pulled out
(after the second case is removed ofcourse).
I managed to unbolt the bolts of the center diff so I could see what was happening inside,
and yes, the gears have a couple of broken teeth.
BUT, the D*** thing still sits in the case and won't come out.
As by now my gues is that the output shaft is all worn out, being
the reason I dont get any movement from the car, nor frontwheel nor rearwheel.
Do you think thats why the center diff won't slip out?( because of being all worn out)
Thanking you all in advance,I remain..
Gino
Gino
