daren_p
DSM Wiseman
- 4,607
- 94
- Nov 22, 2004
Newmarket,
ON_Canada
Posted this up on the Link boards but I know there's some guys here that aren't on there with some good info, so I'll ask here as well:
Time has come to pull the 7 bolt & if everything checks good, I'm planning to build it up. Probably sticking to 2.0 & would like to end up around (or close to 9:1).
Car is currently my summer daily driver. Run pump 94 with 50/50 meth injection on my 3052. Daily boost has been ~26psi & 28 or so at the track. Probably bump that up to 28-30 daily & probably around 32-33psi at the track. I may go with a 35R next year so might run abit more boost at the track (though won't get too crazy as I don't want to get to the point of going through trannies like some guys here do ).
So basically 500-550whp depending on street or track (possibly abit more at the track in the future but 600whp is probably about max I'll ever go) & I'm looking for something that will last. I will be removing the oil squirters.
For pistons I'm looking at Wiseco 1400HD or the Mahl's. For rods I'm looking at H beams, Eagle was my origional choice but also looking at Manley or Scat. Starting to think Scat may be the route to go as I've heard they have an extra oiling hole, which may help splash oil on the pistons.
Was going to run ACL Tri Metal bearings, ARP mains & L19's (stock composite & oringed).
Should also mention (don't think its an issue with my choices) but looking for something without piston slap & how does the warm up time on these pistons compare? I don't mind waiting a min before I drive, as thats what I normally do, but I don't want a setup I have to sit & let the car idle for 5min before I can drive. I know not to beat on the car till its properly warmed up & currently don't get into boost until its fully warmed from light driving, so thats not an issue.
