JackStieben
- 200
- 21
- Feb 11, 2014
San Antonio,
Texas
By dash lights and tail lights went out a little bit ago. I unplugged all my tail light bulbs and put them back in and it fixed the problem for a bit, I did notice that the one of the bulbs behind the tachometer went out so I replaced all the bulbs behind the gauge cluster. I bypassed the dimmer switch, I unfortunately cut the wires so I can't use a paper clip to bypass it through the white connector. I connected the black wire to the black/yellow wire. I also replaced all the fuses and relays. Tail lights, cigarette lighter, etc. Today I replaced all the turn signal and brake light bulbs and it fixed my right turn signal from flashing faster than the left but the dash/tail lights still do not work. The brake lights, head lights, and service lights all still work. I am truly at a loss and any help would be appreciated.
