Cheesepie
- 0
- Mar 2, 2013
Dallas,
Texas
Encountered an electrical problem with the Eclipse recently, specifically the tail lights (+ license plate lights) and the gauge lights no longer work.
Some notes:
What could potentially be the issue?
Thanks!
Some notes:
- I had the dimmer switch bypass for a while now since the dimmer switch didn't work.
- There is no power going to the 15A TAIL fuse under the hood
- There IS power to the TAIL relay under the hood.
- The TAIL relay clicks whenever I turn the headlights on.
- Brake lights work
- Blinkers in the back also work.
- Stereo/headlights and everything else electrical works.
Thanks!
