EC17PSE
Freelancer
- 5,903
- 3,502
- Nov 1, 2008
London, UK,
Europe
The first one i used was a old kit borrowed, the kit i bought was #79005 from longacre
Awesome job.
What us your cars camber setup.etc.
Once my LCAs come in I'll be sending my car off to get set up. But need numbers that work.
Redline power steering fluid will help but beyond putting in a larger reservoir you can wrap the reservoir in pig blanket and monitor the level frequently. It's pretty common in street turned racecars.
Thank you!! It was a crazy weekend. Good times. On to Lime Rock in October.Congrats on the win!!
It was an 11/64ths I believe. I can give an exact size next time I go to the shop.What size and kind of drill bit did you use for the safety wire hole?
Whata the bracing for? Have you got a panel yet to cover this or you going to make one
If the battery is there then thats cool, makes sense,Bracing is just to put a little structure back there and the battery is gonna be back there as well. Making a panel today. Well.....two panels cause I don't have a enough metal to make one panel .
Lol. It helps save a couple bucks.I really should pick up a welder so I can do all this cool stuff.
