98 TSi awd - Autocross Build
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
T25
Drivetrain
AWD
Build Type
  1. Autocross
Foam core air filter / Greddy Type S BOV / RNR Racing 3 inch O2 eliminator down-pipe / Apexi GTspec exhaust / HahnRacecraft SMIC / Greddy UICP / 1g Tbody /
Mods-Engine
Kiggly HLA / 3qt Accusump w. Pro EPC valve / Dual port recirculated catch can / Turbo Tony Vented oil cap / Evo 9 OFH / G-Unit external oil cooler.
Mods-EMS & Logging
Innovate MTD boost gauge / Innovate MTX-L Plus Wideband / OMNI 4-bar map sensor / Ecmlink V3 / GM AIT sensor /
Mods-Drivetrain
Southbend SS clutch with full ceramic disc / Clutch Masters aluminum flywheel / Torque Solutions front roll stop / Torque Solutions rear motor mount / Prothane side motor mounts / Extremepsi shifter cable bushings & shifter base bushings / Aluminum shifter cable trans mount spacers / shortened STOCK shifter with Razo heavy shift knob / Evo 8 rear diff / Quaife ATB Helical center diff / Cusco RS clutch type front diff /
18x10.5 Enkei NT03 wheels / DG spec Koni coilovers, 800lb front & 550lb rear hyperco coilover springs / TCE Performance 6 piston 13inch front BBK / Slotted ebay rear rotors / Hawk HP Plus rear brake pads / RM sway bars F & R / Paul Volk tubular front control arms / MOMO steering wheel / Bobby Gould Fabrications adjustable front upper control arms / CompWorks fender braces / RRE upper strut bar / RRE lower tie bar / Prothane Suspension Bushings / ARP extended wheel studs / Corbeau FX1 passenger seat / Buddy Club P1 driver seat / Corbeau 3 point harness
Background
An autocross car that I can street drive.
Dyno HP
184.4 whp
251.0 lb/ft
Dyno Type
DynoJet
Dyno Sheet Photo Link
Dyno Shop Name
NJ Bentwheel Motor Club
Black95TSIawd
Comments
2
Rating
5.00 star(s) 1 ratings
Share this Vehicle
