jbouvier
- 31
- 0
- Nov 4, 2005
Clarksville,
Indiana
Alright guys I've searched and tried like everything that I've read on here and vfaq to try and set my timing. I've probably accumulated 30 hours in the past two weeks just trying to set it. I just got the engine back it is a 2.3 stroker bored .20 over, hks 272/272 cams, crower titanium valve springs and retainers, as well as stainless steel valves still using the stock cam gears. The problem is no matter how I try and rotate the cam gears the mark is off by half a tooth at best. If I hold the gears sometimes I get lucky and they line up but when they line up I can't get the timing belt over the exhaust cam gear, its tooth on tooth. I tried leaving the timing off a little and string the rest of the belt and tension it because I read that tensioning it can bring it back in time...it didn't. I'm really stumped with this and unfortunately theres no one around to help with this issue. I've replaced the autotensioner and tried moving the gears in like every position I can think of strung the belt and it'll be off. I really don't understand what im doing wrong. I'd really appreciate any input as I'm steadily losing my patience.
Thanks in Advance,
James
Thanks in Advance,
James
