bNasty
- 669
- 3
- Jan 15, 2009
Chantilly,
Virginia
Alright i hate to ask this newbish question but im semi stumped. So as some of you may know i finally got my talon running. fresh motor and everything. I have fidanza cam gears and a gates racing timing belt if that matters. The problem is that the belt seems loose. I followed the vfaq to a t. and the weird thing is, is that when i turn the crank over to check to see if all my marks line up the belt gets tight again. All my timing marks line up and are where they should be. But it kinda sketches me out that that belt would be loose. Its a new oem tensioner, new oem pulley even a new oem arm. everything on the motor is new. Im just stumped with this.
