- Thread starter
- #101
XiKeiyaZI
- 6,967
- 57
- Dec 28, 2008
Goldsboro,
North_Carolina
20-25 repetitions is too many. If you like it, that's fine, but it will limit your overall gains. It is good, however, that you are making sure you are comfortable with a weight before moving on.
So, I should ask since you only mentioned arms and shoulders, are you practicing your squats? Are you using the leg press? And what for your back?
You should lay out your exercise routine more clearly for us. The cardio looked dandy. I wouldn't want my HR that high, personally, but if you're not slowing down or experiencing any discomfort then rock out! Everyone is different.
I used to be in great shape - but I was a teenager and it just came naturally. Haha. Now that I can't be outside 24/7 moving, running, and having fun my body has faded off, so to speak. Cardio was never an issue for me and the high heart rate feels natural. No head-rushes, flashes, or anything like that which other people relay when they get their heart rate too high.
I do fail to mention a bit. I am using the leg press at the same reps, 20-25 at about 100lbs in steady and fluid reps. No jerking or stomping it, or holding an extension, just working it and letting the muscles burn. It's getting too easy so I'll be bumping up the weight this week.
As for back I am unaware of any exercises for the back? What would you recommend? Any actual workout routine suggestions would be great at this point as I've gotten the eating in portions and balancing it down. Plenty of protein, lots of water, stay away from high amounts of sugar and sodium, and a ton of salad. If I feel I haven't taken in the right amount of vitamins I'll pop a multi-vitamin.
