Zex4g63
- 546
- 5
- Apr 8, 2003
Montoursville,
Pennsylvania
I'm going to touch on everything posted. Heat shields would be great. Problem is the factory ones don't fit my turbo or my O2 housing. I had a scirocco radiator here and did not like the way it would fit in my 2G. Afco makes a dual pass that I think may have in the radiator support but I was concerned with low speed cooling of a dual pass radiator(the scirocco is dual pass too). My car also has ducting to direct the air from the intercooler into the radiator. Mounting the radiator on the driverside would be dumb. Hose routing and radiant heat make it not worth the effort. Several Colts and Evos run a similar setup with success. It won't work for a road course car. I highly doubt it would work with ac unless the condensor had a fan on it too. I live in central PA, it might not work in the Texas heat. When I got it done I drove it in stop n go traffic, I drove it up long grades, and I let it idle forever. My EGT's are uneffected and spool up didn't change. My intercooler is 24x12x3.25 for the record. Here's another pic from the otherside.
