1G Passing smog in California
TheQuietOne32
Mar 31, 2015
temecula, California
I have a 1992 dsm with a 4g63 non turbo engine. If I swap it with a 4g63 turbo cyclone engine will I pass the smog test in California? and will I need to swap my non turbo ecu to a turbo ecu or just modify my non turbo ecu?
You won't pass song in California but my car is not street legal and I live in California. My way around it was getting a smog when my car was stock and were my uncle live he doesn't do smog so I just have it registerd there and when I need plates I just pay for them online. Never need smog again. There's certain places like fort Bragg, Ca that don't need smog
I believe you can pass smog, but you will have to take your car to a Smog Referee and explain that you swapped the non-turbo with a turbo. Just make sure all emissions items are still on the engine and functioning properly (no EGR engine codes). It is probable easier to just move to one of these counties that don't require smog :). You can enter your zip code to see if it is exempt.
http://www.dmv.org/ca-california/smog-check.php
You'll have to do a little research but I have heard since the turbo engine was an option that as long as the engine is swapped with all required smog equipment and the engine is from (the same year?) or newer than it can be smog legal. Im not sure if that would mean that you need the CA specific smog stuff or not.
http://www.dsmtuners.com/threads/1995-eagle-talon-esi-evo-8-swap.475267/page-5
look on page 5 post number 118
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
