bradcurtis15
- 223
- 1
- Feb 8, 2010
West Coast,
Washington
I want to get all new Vac. Lines so and Hoses, does anyone know of a vendor who sells kits?
Note: This feature currently requires accessing the site using the built-in Safari browser.
The vacuum lines off extrempsi are great nice and thick wont swell up under boost or pinch closed on vacuum.
if you are looking for an actual kit, RRE sells a kit for all of our vacuum lines and have a choice of colors.
RRE's Larson Silicone Hose Kit
Personally I just buy vacuum line from extremepsi, but like you said you were looking for a kit.
goodluck
Tuning Tip: Red is a good color for all around performance, however with a big turbo blue gets upwards of 10 hp, unless you have stock cams, then only 5 hp. Silver is best for bottom end power, mix with red for excellent mid-range. For NT cars, shift all recommendations one hue towards a warmer color. Yellow hose should only be used on high compression NTs or turbo cars with welded differentials. Proper Sticker Tuning can be a successful work around for any of these concerns ;-P
Intercooler Pipe Fabrication - Silicone Intake Systems Auto Parts pick up a shop kit.
Tim Zimmer via Evo Phone
