RadDsm
- 1,679
- 23
- Apr 28, 2008
Eugene,
Oregon
I've done a lot of searching and tried everything I can find and think of.
When the car is off it goes into every gear just fine, but when the car is on it won't go into any gears.
It has a new ACT 2100 pressure plate with a Southbend kevlar disk and an Unorthodox 11lb fliywheel that was machined to the correct step height. It also has a new master cylinder and I've tried 2 different slave cylinders from NAPA. It's been bled thoroughly over and over and there aren't any air bubbles in the system.
The trans/bellhousing are all bolted on tight with no gaps, the shift fork is not bent, and the shift cables look fine.
Any other suggestions?
Are the NAPA slave cylinder rods maybe not the same length as OEM?
Thanks in advance for any help or suggestions.
EDIT: Thought I should add that the slave rod has been adjust even all the way out and it doesn't help.
