doubleclutch
- 830
- 175
- Jun 26, 2009
Canton,
Michigan
First off:
1). Any boost, vac, or exhaust leaks? No
Boost leak tested 5psi above your max boost with no leaks? Yes
2). Verified mechanical timing? Yes
3). Verified base timing? Can't Yet (see post)
4). Ignition system
COP or Stock Coil: Stock
Wire brand and Age: LC2 - 0 Miles
Spark Plug brand, type and Gap: NGK BPR5es
5). Motor health (Compression Test) incomplete
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
6). Performed basic throttle body adjustments?
Idle Switch: yes
Throttle Cable: Yes
TPS: Yes
BISS: YEs
7). Compression ratio: Stock
8). Any known bad sensors or brittle wiring? No
9). Any DTC/CEL codes? No
10). Electrical system
Car off (not running):
Car running: 14.4
Base Fuel Pressure: Stock 42.6psi
Injector Size (cc/min): Stock 450
Sensor Brand: LC2
Calibration Date: 4/28/16
13). Type of fuel
Type: Premium
Percent of Ethanol: 10%
14). Watched ECMlink how-to videos? Yes
OK So:
I was going through this list after my 16G, fuel pump rewire, and LC2 install preparing to tune and found that my mechanical timing was off 15deg. I pulled the timing belt and reset it to where it should be. Started the car ran ok for 10-15 secs. Unhooked the battery and re-did the belt for piece of mind (forgot to put sealant on the tensioner bolts) and put it all back together. I fired it up and now it is jumping the base timing all over. I am at a loss. I completed a BLT and no leaks. The log is attached below. With some throttle it does fine. Without it it runs crazy bad. The boost gauge also vibrates around 10 inhg when not on the throttle.
I was able to get the air/rev where it needs to be and the ISC. it helped a little, but the fuel trims are going crazy too.
Any help would be great.
Thanks!
4). Ignition system
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
Idle Switch: yes
Throttle Cable: Yes
TPS: Yes
BISS: YEs
Car running: 14.4
Sensor Brand: LC2
13). Type of fuel
Type: Premium
OK So:
Thanks!
