spoolinawd91
- 40
- 0
- Jan 10, 2005
Mt. Washington,
Kentucky
I think some odd is going on with my 2.4, I have FP2 cams and I see about 14-15 vac at idle (1000rpm) and only about 19 when I let off in the upper rpms. My question is does this seem normal? And what kind vacuum readings are people seeing with your strokers with cams at idle and when you let off in the upper rpm's? Reason I ask is my car runs rather rich and also from what I've been reading (did a search) the vac I'm pulling is what most 2.0L's do with these cams.
