Please Support STM Tuned
starter issue.
koryto2012
181
Nov 24, 2011
Indianapolis, Indiana
Last night i finished putting the car back together after putting a new clutch in. When i went to start the car, nothing happened.All i herd was something spinning. So im assuming it's the starter. The car worked just fine before the clutch went out. Never had a starting problem. Just curious if anybody knows how to fix this.
Thanks.
Make sure that the starter bolts are tightened all the way and make sure that all connections are good. Maybe give it a tap while trying to crank it to see if that helps anything. Also, if you haven't already done so, make sure the battery is fully charged.
