Resolved snow injection NO BUNG need options asap
lasershark
1,607
236
May 17, 2013
over yander, Idaho
So I don't know if the kit is supposed to come with a nozzle bung or if you are "supposed to" thread the nozzles directly into the piping? :confused::confused::confused:
Either way if anybody knows an acceptable alternative to buying a bung and having to wait for shipping yet again that would be great!! (maybe a nut size to use as a bung??) Just want to make sure the nozzle is right.
Or if you are supposed to thread the nozzles directly into the piping, I would think, Boost leak??
Need a little insight
as always THANKS :thumb:
Did I get skimped on the bung or do you have to buy that separate??
You need a bung welded into the pipe. Or buy a pipe with them already in, silicone intakes sells them.
From what I found the bungs are 1/4" think and obviously the 1/8" npt that you are supposed to tap the intake pipe with. I am going to check a hardware store to see if I can get lucky.
I figured a bung is pretty much mandatory considering the thickness. or lack of I should say, of the intercooler pipes.
I guess the kit doesn't come with them, an oversight on my side I guess. I would think it would come with it.
Thanks Kauai I'll check out silicone intakes as well, what ever saves me time!!
