ZachM31
- 427
- 9
- Aug 30, 2004
Moorhead,
Minnesota
I've been searching for a number of days now and I can't seem to find a solid answer to my question. I have had my CEL on for about a year because of a "Massive Leak in my Evap System". I assumed that it had to do with my Evap Can (Charcoal canister) so I finally began to fix the problem by removing the canister. On 98-99's, the canister is behind the front bumper on the driver's side. To cut to my question, I removed the canister and now I have 2 lines left open to the atmosphere (they are the hard lines that run under the radiator and are attached in the same spot that the radiator fan bolts thread in to). They both went directly into the canister, so i assume that one is the "in" line while the other is the "out" one. Should one of these lines be vented? And also, can I just remove both of the lines all the way back to where the battery is and hang a line off to vent the fumes under my car? I hope my question is clear enough, if you need clarification, I would be happy to do that!
