Blinkyblinx9
5+ Year Contributor
- 89
- 21
- Jan 22, 2019
Clinton,
Iowa
I'm not trying to regurgitate the same questions that have been asked over and over but I have looked and looked through the forums for solid info on this topic and I have found few if any useful or productive and not conflicting replies. I also don't want anyone to think I'm trying to come off like an ass. I'm going to ask some stupidly specific questions that I feel were asked in the past but were phrased too broadly so the responses were quite generalized. So, with that out of the way on to my questions.
1: You can put a cyclone manifold on a 2G head right? I mean nothing is technically stopping a person from physically bolting it on and firing up the car and having it run (just run) with no trouble? The ports aren't offset in a way that prevents the parts from forming a proper seal? No other weirdness that needs to be considered?
2: If not then, what stops a person from just making like a 1-2inch adapter to port match instead of porting the 2g cylinder head itself? I have searched for days and days an the only thing I see is either "you cant do it" with absolutely no explanation other than the ports don't match or "you can but you would have to port the heck out of your head to the point that it eliminates the benefits of the 2g head" which does kinda sorta conflict with the ohh so typical "you cant" response. I mean, if it is just a difference in port size how big could it be like 3mil all around so 6mil diameter difference or less even? That can easily be blended with an inch or two long adapter.
3: Has anyone ever actually put a cyclone mani on a 2g head effectively whilst retaining the flow characteristics of the 2g head? If so does anyone have VE table adjustment comparisons from link or dyno sheets anything that shows any gain at all? Low end torque is rather hard to get a hold of on our cars at a reasonable price so if I can drop 300 on parts and machining and spend a few days fiddling around with this and get even just 10-20lbft at 3k without loosing anything up top its worth it to me over stroking the block. That's going to cost a few thousand and won't net me hundreds of lbft.
4: What other things need to be taken into consideration? For instance (if i remember correctly. its been a lot of reading on this over the past few days) I read something about a bracket that needs to be mounted to the AC compressor on 2Gs? I'm assuming the cyclone mani weighs a good bit more than the stocker so its just to help brace the weight and ease load on the intake manifold bolts and cylinder head.
I want to know everything I can about this before I pull the trigger on a 3-400$ likely month long experiment.
