Atuca
Supporting Member
- 1,140
- 293
- Jan 6, 2007
Central Valley,
California
Hello all,
I would like to begin a conversation that I believe was self answering after it was brought up to me by Eric (Turbosax2) himself.
As I was building my race car, I came into reasons that required the relocation of my battery. The obvious solution for years has to been to place it in the rear of the car for better weight distribution.
That was until the invention of Lithium car batteries.
Lithium Pros C680 12V 800 Max Amps Powerpack Battery
If I am not mistaken, at less then 5 pounds, this battery possess the cranking amperage needed for our engines and would be perfect for my race car. Its a bit pricey at 500 bucks, but when we are talking about a race car where every pound counts and dry cell at 10-15 lbs and stock batteries being close to 40 lbs, it is a price I am willing to pay.
I have read you can build your own lithium battery and maybe I'll ask some questions about this in the existing threads here on tuners, but my dilima:
I have already purchased everything (except a battery) for the battery relocation as listed here in Eric's thread:
http://www.dsmtuners.com/forums/han...-relocation-project-log-16.html#post152022910
This is a very nice high quality collection of electronics and wire, but this is not something that is light. In fact it is extremely heavy, at what I would guess easily 20 pounds in wire if not more. While I plan to place the cut off switch at the Driver side A pillar of my roll cage which will save running both the alternator and starter wire front to back of the car in the instance Eric used with his rear mounted NHRA legal cut off switch, there is still a considerable amount of weight that would be added to the vehicle in wire that would completely negate the weight savings of the battery.
With a lithium battery you are losing the weight distribution over the rear passenger wheel battle, it becomes a matter of pure weightloss, not weight distribution, and at that point I can save weight leaving the battery mounting above the sub frame or maybe in the car near the firewall (in its battery box of course).
That is my dilima, and my question would be, what are you guys' thoughts. Are there rules specifically about where the location of the Battery can be in accordance with NASA and SCCA? Would you place it in the back of the car anyways to just keep it out of the way and out of the engine bay? If its mounted above the subframe, are there mounting kits available? Am I doing this all wrong and should I just use a relay switch like this:
T1 Battery Cutoff Kit
Here are the rules I could find:
http://www.nasaproracing.com/rules/ccr.pdf
Please keep in mind this is 100% track only race car, and suggestions should be based on the mindset of quickest lap times.
Thanks!
18.8 Battery
The battery shall be securely fastened down to the car. No Bungee cords or rubber
cords may be used to function as the sole hold down mechanism. An electrically nonconductive
material must cover the positive battery terminal. Any battery located inside
the drivers compartment shall be fully covered and firmly secured to the chassis in a
marine type battery case. True dry cell batteries may be mounted without a surrounding
case, however a case is still recommended. Note- there is a difference between dry
cells and gel cells. Gel cells still need to be mounted in a case.
18.9 Exposed Wires
There should be no exposed wires inside the drivers compartment such as to interfere
with the safe operation of the vehicle. No live (hot) wires may be exposed anywhere in
the vehicle.
Thanks!
