Please Support STM Tuned
Please Support Rix Racing
2g 6 bolt swap CAS adapter harness
Dasean Real
Apr 2, 2018
San Diego, California
I have a 98 gsx, 6 bolt and 98 black box ecu. i have a fresh adapter harness for the CAS and i am unsure where to connect the 4th white wire on it
Should be a matching connector near the TPS. I have the same harness. My wire is blue but you can see right where it goes. Start your search there.
ok so take apart the white plug on the CAS harness and the 3 wires from the cam sensor and solder the white to the blue wire that has the red stripe on it? then leave the rest of the wires alone?
actually that looks like you have the right plug on your harness. so the plug at the end of the white wire gets plugged into the plug off the cam sensor. so its just plug and play
sorry i didn't snap on what connector was on the end of the white wire. i was thinking it had the 95-96 connector on it. like this
I liked your diagram, you should have left it up for reference purposes :thumb:
Here ya go, its back
http://roadraceengineering.com/blog/2015/01/08/2g-eclipse-1g-motor-swap-cas-harness/
http://www.roadraceengineering.com/1gcasin2g97-99.htm
On ’97-’99 Eclipses, if the white wire on your adapter harness has no connector or a 95/96 connector on it,
the blue/red wire from the 2G CAM sensor plug needs to be solder to the white wire coming out the CAS adapter harness.
(cam sensor has a blue/red wire at pin 2, crank sensor has a blue/white wire at pin 2)
Thanks man idky i didnt think that it fit the connector the shape deceived me, car finally stays on i appreciate the help yall
