JusMX141
Moderator
- 15,148
- 1,269
- Dec 13, 2005
Greensburg,
Pennsylvania
That's a half-ass way to repair a blown gasket that is putting air into the cooling system. By removing the stat you're taking out the barrier between the head and the radiator which likes to create air pockets.Go and remove the water neck; No thermostat!?!?! haha i hope this fixes it
You need a head gasket.Still overheating.. but lets say if its at normal op temp; itll stay there at idle.. if i cruise and it overheats i pull over itll stay hot at idle..
If its 3/4ths or a little over middle to hott and i stop at idle; it stays there. it won't go up or down...
is going on?
