The 4ce
- 7
- May 8, 2018
San Diego,
California
A bit of backstory... I am doing a frankenstein awd build on an old '74 Colt. All suspension/chassis datums and hard mount locations have been tossed by the wayside. Due to parts scarcity, I'm trying to figure out interoperability of parts. In this particular case, I am trying to figure out if the 1G Front AWD Driveshaft (non-ABS) will properly mate/mount to a 2G AWD Front Hub Assy? Keep in mind that I will be relocating new mount points for the hub assembly, so the classic driveshaft length issue between 1g and 2g is not really the limiting factor. I just need to know if a 1g front outer shaft with integrate with a 2g front hub assembly.
