92AWDHX40
Supporting Member
- 13,632
- 1,585
- May 22, 2007
Kalamazoo,
Michigan
Nice thank you for the update .
Looking good bro, it’s crazy our builds are very similar. Keep up the good workAnd just like that, it’s time for another episode.
I finished the prep for the valve cover and compressor housing by blasting them again and polishing the letters. For the valve cover, I made a baffle out of aluminum using the stock baffle as a template. I only made it to cover the openings for the PCV and Catch Can and had it tacked into the valve cover.
View attachment 538830 View attachment 538831
After that, I coated the two part with the same two coat process used on the brake calipers. The only exception is that I used a wet finger to wipe the powder off of the polished letters. This is the result.
View attachment 538827 View attachment 538828 View attachment 538829
I was super excited about the outcome and couldn’t be happier. There are some imperfections but not bad for my second try at the 2 coat process using hobbies equipment.
I installed them on the motor. The valve cover received stainless steel bolts to really accent the color.
View attachment 538832 View attachment 538833
With the compressor installed, I loosely installed all the intercooler pipes to finish fit the radiator and intercooler.
To install the radiator, I drilled new holes and installed rivnuts to utilize the lower brackets that came installed on the radiator.
I then drilled holes and installed rubber grommets to prevent metal on metal contact. I did this on the lower mounts and the upper tabs that we had installed.
I had upper tabs welded on to utilize the AC condenser mounting points to securely mount the new radiator.
This is the radiator bolted up and installed.
Next we tightened the clamps on the intercooler and began to make our straps to hang the core from. I also threw the slim fan in there to make sure that we had clearance. After a short time, this is what we came up with.
During all this, I had to trim a bracket and I burned up some of the paint. In an attempt at a quick fix, I used some spray can white to try and hide my mistake...... lets just say that didn’t work.
I ended up going back to the folks at single source and having them mix up 6 ounces of the polar white in a single stage paint for touch up purposes. They also sell this neat aerosol kit that is perfect for touch up work so I pick up one of those as well.
After preping and spraying the spot, this was the outcome. I was pretty happy with it.
With the intercooler mounted, I final installed the exhaust manifold. I used metal free anti seize on all of my exhaust parts because I have had awesome success with this stuff on the hot side.
I have to order a T3 gasket but with the bolts snug, I was able to redo the turbo oil drain using the drain from the HX35 that we made in a previous video. All I had to do was cut off the existing hose and replace it with a slightly longer piece.
Another part that I coated along with the Valve cover was the Slave cylinder. It was rebuilt a short time ago so we coated it and rebuilt it using the existing parts which where in great shape.
I applied some grease to the shift fork and installed it.
The CAS couldn’t be coated so I painted it using the same paint as the transmission and installed it. When installing it, I replaced the O-ring and insured that the alignment marks where correct when installing the CAS.
View attachment 538847 View attachment 538848
That pretty much wraps it up. Here is a shot of where we are ending.
And one Glamor shot of the Compressor Cover just cause......
Thats it for this one.
Happy Boosting
What Fmic size did you go with.
Is it weird that read everything in your accent as if I were watching your YouTube channel? L O L
hey Robert where are you mounting your afpr and are you running stock lines or an from the tank to the filter.
