Please Support Rix Racing
Evo 1 CD9A
Ownership Status
Currently Own
Vehicle
1993 evolution 1
Drivetrain
AWD
Build Type
  1. Street
  2. Drag Race
Mods-Engine
Genuine evo 1 GSR CD9A
Evo 3 running gear (gearbox, transfer case etc
Bottom end -
Forged 4g63t 7 bolt (built by 6boost)
Jun 2.2ltr billet stroker kit
Jun crank
Jun billet I beam rods
Cosworth pistons
Fluidampr balancer
Head -
1mm oversize ferrea valves
Brian Crower springs with titanium retainers
Kelford 272/278 cams
Tomei adjustable cam gears
Kiggly hla pressure regulator
Magnus L19 head studs
6 piece Hks fine tuning timing belt kit new
New oem rear main seal
Link G4X evo
Whitey’s Custom engine harness
R35 coil on plug ignition kit
Link Can lambda
Link Flex fuel
6 bar Map sensor
IAT sensor
Bosch knock sensor
Bosch Fuel and oil pressure sensors
Hypertune inlet manifold
S90 TB
Injector dynamics 1700cc
Works fuel rail
Turbosmart 1000 fpr
Radium surge
Wallbro 255 lift pump to twin Walbro 460 pumps (staged).
All new Braided lines -8 feed -6 return
6boost manifold
Gen v 50mm turbosmart wastegate
Garrett G30 770 .83rear housing
3 port Macvalve
Turbosmart Bov
SS 3” full custom turbo back exhaust
Plazmaman intercooler pro series
Mishimoto X-line radiator
Mishimoto oil cooler
Direct clutch twin plate
Competition clutch fork & throw out bearing
Cusco engine mounts
DBA t3 slotted rotors
Koya drift teks 17x8 discontinued
BC racing coil overs
Mods-EMS & Logging
Link G4X evo 123 plug in
Mods-Drivetrain
Evo 3 GSR
  • Like
Reactions: Dashnizzle
Comments
There are no comments to display.
Wrathvr4
Share this Vehicle
