Sws
- 238
- 0
- Aug 1, 2012
Mount Vernon,
Illinois
Have since redone all the tint because it was fading.
What should I do next?
Note: This feature currently requires accessing the site using the built-in Safari browser.
side skirts
high rise wing
Maintenance
side skirts
high rise wing
Fog lights
Rims!!
wider tires
suspension
Actually i used to have a very similar car to yours, i hated sooOo much
Home Depot lip mod, get rid of the front plate bracket if you aren't going to use it, defog your head lights or get new ones and do a headlight retro fit!!, and all the above.
Fixed that for you!
Well if you do the retro fit then that would be a great chance to clean the lens' or else just buy new headlights and have those as back up.
Lol, live and learn but definitely get new headlights if you do the retrofit. I'm in the process of buying everything to do a retrofit for my car to do while my car is stored through winter (and finish building block for turbo!) Should be all kinds of fun!
Also are you leaving your car stock or do you plan on going turbo anytime??
Well im getting everything off of theretrofitsource.com. For my headlights I need the Acura tsx projectors (smaller), then HID lights and ballasts and then time and patience.
You should look there they have a complete retrofit kit for the mini morimoto's (which I think someone else is using on here) starting at $295!!
What are the side skirts that kind of have a big indent and look super sick? I've seen them on tons of different models so i'm not sure which they originated from.
If I'am not mistaken, I believe the ones your speaking of are from a 2ga talon.
Yup that kit should work, only thing I don't know anything about the shrouds. Like size difference and what not but nothing a dremel can't fix! As for the cut off I have heard its pretty good, I'm trying to track down the guy ps write up that did a hid retrofit on his eclipse right now.
SWS - I would also up the bulb to 4300k, right in that nice white range with a good blue cutoff line. Here's a link to a guy with a 1g here on tuners - http://www.dsmtuners.com/forums/app...or/443547-1gb-quad-hid-retrofit-progress.html
yes, first and foremost...pleeeeease do your maintenance. you wouldn't want a nice looking car, looking real nice, stuck in your driveway now would you?
but if you must, cosmetically speaking...
1. yes, defog head lamps.
2. please dont install euro tail lights.
3. if you're going to keep the black rims, maybe install a carbon fiber hood? you need something to support the high contrast between white - black. so many cars look so ugly because their owners just throw black rims on, to get that "tuner" look. I've seen some really nice DSMs with gold rims.
4. please don't get a high rise spoiler unless its the OEM gsx/gs-t one.
5. lower it, but with performance in mind. dont just drop it, just to get it closer to the ground.
I disagree 100% on the rims. He has black windows as well as black door handles. Panda's are pure sex, please don't put a ghey different colored hood on it. Perhaps smoke your tail lights or even black housings in the headlights if you decide to do the retrofit.
Maintenance, maintenance, maintenance!
Then get rid of those wheels and headlights!
All in all, sweet looking ride man. Out of all of the cars I have owned, I've never managed to snag a white one... Always wanted white. I envy thee. Lol.
