- Thread starter
- #26
TheBrownMike
5+ Year Contributor
- 56
- 74
- Apr 9, 2018
SAN DIEGO,
California
These cars look SO much better with window tint, I need to get mine done still
The crud was a mixture of small granulated stuff and bigger flakes, definitely mostly metallic. Fuel gauge still reads fine, the low fuel light seems to come on around 1/4 tank, seems a little early.I can totally relate to your first challenge with this project, that being the fuel tank full of crap. Yours looked more like dirt than rust. I take it your fuel gauge still reading OK?
Muffler looks great to me. You’re wanting it slightly closer to the side? Since these bumpers never had any kind of indent for clearance, as some cars have, only other dsm fanatics can even detect the difference.
Turbine wheels are one of my favorite features of the oem look, and a factor in why I bought my car. Interesting that of all the 1g that have sold on Bringatrailer, I don’t see any with ‘cheese slicers’..?
You’re car looks great, either way.
I don't feel like there was too much of a difference so far, but I'm also used to bumpy/vibe prone vehicles. I am interested to see if it changes once the rear mount is in.Oh! You can maybe test a theory that I have heard about how most of the unwanted vibrations from poly mounts come from the rear mount. Curious, how bad are the vibrations with a stock rear mount?
242* seems pretty hot to start the fan, hopefully you can get those temps under control.
Hey, Mike! I've been following the build and really like what you're doing here!I don't feel like there was too much of a difference so far, but I'm also used to bumpy/vibe prone vehicles. I am interested to see if it changes once the rear mount is in.
The new thermo switch in the t-stat housing seems to work as far as turning on way earlier, around 185-190* according to link. Unfortunately it stays on basically the entire time the car is running which is not ideal. The car seemed to stay cooler longer but once again got up to the 223-226* range.
Putting the restrictor in the boost reference line got the WGS working in link, bumped it up to ~75% duty cycle and that got boost up to 20-21psi. Car keeps going lean under boost and knocking/breaking up. Adjusting SD cells didn't seem to make a difference either. This prompted me to check all my intial settings, base timing, IAC position, fuel injector sizing, etc. When I checked fuel pressure I realized it was at 45psi, so bumped it down to 37 and changed the vacuum line to be direct, bypassing the FPS. I also swapped to some BPR7ES plugs, gapped at .026. We will see if that helps with both the stuttering and temps. The car feels GREAT when its in boost and not leaning out, so I'm excited to see what happens once I fix the issue. Link HP estimate was 298 at 15* timing and 20psi which is a cool, haha.
