Please Support Morrison Fabrications
Please Support Rix Racing
What Turbo is this? [Merged] Turbo ID Identification
Here it is all thrown together. 7 blade compressor. 11 blade turbine.
Older Green XL (76HTA compressor on a TD06 turbine) circa 2011/2012 when FP was still using CHSH 7cm2 housings. Watch for these housings to crack around the wastegate hole in the same area the newer 8cm2 housings do.
In reality, your compressor cover was made by CHSH also...FP just casually ground off the identification badge so folks wouldn't think they were using aftermarket turbo parts.
See picture below.
Good deal! It’s going to be externally gated so hopefully I won’t get any cracks
There is nothing. The reason they're using aftermarket housings is because OEM MHI housings are no longer in production. So once it's toast, you can either buy a different turbo or possibly find an older non-Evo III spec 7cm2 MHI housing that isn't cracked and get that machined to work.
Oh alright. I’ll run it till it blows up. Got it for free anyways. And it will be a conservative tune. Thanks for your help!
Hi,
I was hoping someone would be able to help me identify this turbo housing, i am trying to find the guts to go inside but need to make sure i get i right.
the intake is 4" with the impeller being around 2" +/-
Any help will do.
Thanks.
Got this turbo in a trade and for the life of me can't figure out what it is since the owner didn't know either. Hopefully someone here can help me
Wheels specs would help, but looks like some chebay t3/t4 60 trim?
Which I had more info to give but everything on the turbo is all the info that I have to go with also. If it is a Garrett knock off it is a pretty good one at that
Long shot but anyone know what kind of turbo this is ?
KD090002663 ,
I have a brand new 14 b that I'm planning on using but curious what this is thanks
Didn't want to start a new thread LOL
