Please Support RTM Racing
What the normal oil pressure?
BLOHS7844
300
Oct 25, 2011
Appleton, Wisconsin
Normally, when fully warm, my oil pressure at 2500rpm is about 50psi. Just wondering about other people to see where that compares. Using Royal Purple (5w30) its usually a couple psi lower than Mobil 1
What is it at idle? 750-900 rpm your oil pressure should be 11.5psi.
Mine never goes that low. And it won't idle that low either so that's why I don't use that as a baseline. It idles somewhere around 1000-1300 depending on absolutely nothing. I use 2500 rpm as a baseline because that's what 60mph is in 5th and thats where I spend most of my time
