jayson427
- 1,515
- 3
- Dec 20, 2011
Mesa,
Arizona
"Something with a larger turbine wheel or higher a/r number on the turbine housing to deal with the additional amount of exhaust energy. A small turbine or small a/r housing will funnel the exhaust energy into too small of a space, raising backpressure and EGT's which are NOT what you'll want to be dealing with on a high-compression application.
Some guys have said a 50-trim, and that would be fine as well....but if it were possible to still get this built, I'd say use something like a 60-1 compressor with a T350 turbine wheel in .63 a/r T3 housing. PTE used to call that wheel combo a SC6052E. That should give you an easy 300whp at just 15psi or so, while reaching full boost in the 4200-4300rpm range and remaining very easy to tune on pump fuel."
this quote above was on one of my threads by justin and im curious what is close to a sc6052e? im just starting to read up on all the turbo sizes and what is better for what. i read that most holset's spool up faster then a garret which i like the sound of that, im going for around 300hp but would like a little room to grow if needed. any help would be appreciated. this turbo would be for a 10.5 comp built motor and currently running 2.5in exhaust.
