dfootedsm
- 269
- 20
- Jun 3, 2013
Botswana,
Australia
My turn signals and hazards are not working, I have had several solution attempts.
My alternator failed on me shortly before this issue arose. the surge fried several fuses and switches. I have replaced my wiper switch because it went haywire. My turn signals began the hyperflash but no signals outside the vehicle just the dash indicator. I replaced my flasher which was a pain to find BTW. The dash indicator returned to normal speed, however still no signal outside the vehicle. I changed my signal wiper switch assembly still no luck . I recently found a 30 amp fuse had been put in my fuse block for my circuit. ... clearly more than needed and im not sure what things I should check and the possible issues it may have caused?
