Please Support Rix Racing
Please Support ExtremePSI
Stripped bolt hole for transfer case on transmission
ErikTande
Supporting Member
1,508
569
Dec 17, 2012
Centennial, Colorado
One of these bolts on my transfer case is stripped, I must have over tightened it. Can I drill, tap and helicoil these without any issues? There's no oil / fluid passage there, right? I circled both because i don't remember which one I stripped.
I did this before also. I couldn't get the proper size helicoil for over a week and needed the car running, so I tapped the hole in the next larger size in Imperial course thread and put in a new grade 10 bolt. Just another option if you cant find the right size kit locally.
My first choice would be Helicoils if the holes aren't oversized too much so the Helicoils won't fit poroper. I would also Helicoil all the holes while fixing the stripped holes as well. My opinion is all threaded holes in aluminum should have Helicoils. If you have the resources make yourself a drilling guide block to help keep the drill straight.
Good tip, thanks!
