dsm-onster
DSM Wiseman
- 8,592
- 124
- Jul 11, 2004
Bloxom,
Virginia
Well, I have not brushed up on my materials and statics courses, But I was thinking about this the other day. . .
Most would assume that the shear stress applied to a head fastener such as L19 or typical ARP head studs is quite miniscule. And I agree.
But considering the higher the carbon content in the steel the better the tensile stress resistance, wouldn't there be a point where such minor shear stress would cause a head fastener to fail? I do know the more carbon content, the weaker the tensile stress is neccesary to degrade the metal. As I see it, we can't assume that the forces applied on the head during combustion do nothing to push the head in the same planar direction as the deck. So am I just out in left field, or is there another good reason to O-ring the block/head other than shielding the head gasket from combustion? Having the head more anchored with respect to force/motion along the same plane as the deck, wouldn't that allow the much higher carbon steel to do it's job against tensile stress without the worry of the loading in shear being too much for that same high carbon steel?
Is that the REAL reason engine builders O-ring blocks?
