safarijeepjim
- 0
- Oct 25, 2012
wenatchee,
Washington
Is the ac condenser in front if the radiator supposed to get hot when the ac is not on? Reason I ask is because the other day I was putting a new radiator in, when the old one was out I was pumping water in the motor while it was running to flush the system and within just a few minutes the ac condenser was too hot to even touch! The ac was not on. After the install I also noticed that the rpms were very sparatic at idle when I did put the ac on. When driving in these hot temps it will blow cold, but was causing the motor to run around 215-219, so I kept it off. But today I had to actually run the heater in these 100+ temps when I was hitting the steep hills on my way to work. I'm guessing that the hot temps from the condenser isn't helping the radiator to keep cool by any means... Any ideas guys?
