Please Support ExtremePSI
How to Identify an EPROM ECU [Merged 5-9]
How do you know if you have a 95 or 96 I was told this is a 96 but not sure it says
md312464
e2t61672
4919 E
And it dose have the chip in it and it came from an tsi can any one tell me if it is a 96 or 95 and can it have the 3.0 dlink ?
And was 75 to much ?
Yes, you have all the right numbers, and you stole it for $75. ;)
I highly recommend that you have it professionally socketed, as the 2G traces are very fragile when compared to a 1G. After socketing you can run one of my DSMChips, a DSMLink setup, a Moates Ostrich emulator, or burn your own chips.
keydiver
One of my friends gave me an Ecu out of a 2g talon Tsi, AT i think and i was wondering if it was Eprom or not . code on the top is , MD304481 , E2T60885 , 3728 E , Mitsubishi Electric corp , right side says 4481 E2T60885 , sorry if this is a Noob question , or if its already been answered , thanks
Are you sure that's the right model number? (MD304481) That is a non-turbo 1g, fwd, automatic ecu. Also, to be sure if any ecu is eprom, you can open it up to see.
http://www.dsmtuners.com/forums/newbie-forum/169843-ecu-md304481.html
6/93-5/94 - MD304481
E2T60885
EB20
Ok I know this isn't a eprom.
But why does it look different from the other non eproms I see?
This is out of a 90 GSX, the funny thing is I thought all 1990s had eproms?
Mine pulled from parts car...
MD145903
A non eprom, notice the were the e-prom chip would be on mine its different.
1990 ECUs are just laid out different (and have some different circuitry) compared to 1991-1994 ECUs. Notice that you also have four vertical riser boards compared to three in the picture off our website in your post. The 1990s are just different.
Thomas Dorris
That's a myth. Your holding proof that it's a myth. There wasn't any year of DSMs where they were all EPROM ECUs. Just wishful thinking on somebodies part that got written down.
Hey whats up guys? I decided to finally check to see if my ecu is eprom or not, took a look at the case and it has a T instead of an E, but I've read that doesn't really mean if it's eprom or not so I opened it up. I look at it, and it looks different than the ECU's i see in other threads. Can you guys help me identify if it is or not? thanks
On the bottom right chip it says "EL62" and the ECU number is JE331B719C
Sorry for bringing up the dead but I'm trying to find out if mines eprom...don't think so but want to be sure. I ran all the #s and it's a 97 turbo but it's the black box, not the metal and whether or not it's eprom, I wanted to see if it can still b chipped so I can run link. Picture following n a minute.[DOUBLEPOST=1412193804][/DOUBLEPOST]Pic
