Nuzzi
- 158
- 5
- Jan 11, 2014
Torrington,
Connecticut
First post, been lurking here for quite a while learning about these cars. This is my first DSM, I grew up around Euro and American classic/muscle cars. I always liked the 1g Talon and recently bit the bullet when I found one for a pretty good deal. It's a '91 Talon Tsi 5spd in pretty good shape just been sitting for a while. 159k, level 6 trim, blue/grey paint with grey/black int, no sun roof, lsd rear, no rust and several upgrades. It runs great but needs a good amount of work before it can even be driven, had to have it towed to my place (don't worry, used a 4 wheel dolly) I can tell the engine has definitely been out at some point and looks like the head and valve cover were recently off, I haven't had a chance to peek under the vc yet, hoping by some miracle there's a set of nice cams in there. The previous owner did some weird things with the ecu among other issues that I've since resolved (typical vacuum line nightmare under the hood) The car is definitely a '91 but for some reason he swapped the 2 pins around to use a '90 ecu....the car even came with an extra ecu also a '90...and he told me he was planning to buy the tach converter from dsmchips, he was clearly confused as to what he had. So I know I need an ecu at this point and fix the wiring, the other major issue is that he had bigger tires on the front! 215/60/16 with the stock 205/55/16 in the rear, so I can be pretty sure the viscous coupler is shot. That being said, do I need to be worried about other driveline issues besides the vc that would be affected? How bad a job is it to do the vc? (it also needs wheel bearings all around) Overall the car isn't too molested so I hope to have it on the rd by summer time.
