TEAMHYBRID
- 0
- Oct 13, 2011
orlando,
Florida
I NEED A COIL PACK FOR A 95 GST I HAVE LOTS OF PARTS I CAN TRADE. I have 2 coil packs but i have no way to test them other than putting them on a perfectly running engine to see if it is the problem.
I have replaced the fuel pump with a EVO VIII fuel pump
i have replaced the fuel filter
I have replaced the spark plugs with E3's
compression is good in all 4 cylinders
removed and cleaned each of the fuel injectors
the car was running great and one day it felt faster than normal I had not messed with anything and it seemed like it was getting more power from somewhere but it was misfiring badly.
The next day it will hardly run or even start. When I rev the engine it smells rich and it is slow to rev to redline.
I can unplug the injector #2 and the engine will run the same.
