killercolt
- 311
- 23
- May 23, 2008
Acworth,
Georgia
I finally got a chance to do a comparison test between the Honda intake manifold and the cyclone intake manifold. The tests are on the same day with relatively the same conditions.
Here are the mods that my friend told me are on the car:
2.4l 7 bolt block
Manley flat top pistons (calculated 9.2:1)
88mm 7 bolts Cosworth crank
162mm super long Manley rods
1g head with light street port
Stock size ss valves
Manley springs and retainers
BC 272/272 combo
Cometic head gasket
Kings bearings
Bs elimination
Shep stage 3 transmission
Act 2600 with 4 pucks disc
Fp turbo manfold with home made Mitsubishi to t3 adapter
Gt3582r with .63 a/r
Hks electronic boost controller
Tial 44mm wastegate (10-12psi springs)
3" exhaust
4" vrs intercooler kit
Ecmlink v3 full version
2g unhack maf
1200cc RC injectors
Bosch Full pump (forgot the number but it is not a 044)
Unicorn blood (E85)
Here is the graph of the run with a "cyclone intake manifold" at 22psi. Timing was around 14-16 degrees. It is not too bad for 22psi. Turbo is a little laggy for a .63 a/r. I believe it's is due to the weak wastegate spring.
Here is the engine pic with cyclone intake manifold:
Here is another pic with the cyclone intake manifold:
These are pics of the Honda intake manifold on the same car. This is a 2g Gsx. Notice how well the Honda intake manifold fits. It fits all DSM'sand CSM's.
I am pointing at a perfect mounting point for the ignition coil
Now for the comparison. Try to look at the conditions of each run. They are hard to see on the graphs. The conditions are very close to be the same. I try to be as fair as I can with the comparison. No ignition timing change was made. I try to get the afr to be the same only to keep it safe. Boost is 22psi for both intake manifolds
This graph shows the hp different. The cyclone made 3 more peak hp. The Honda intake shined after 7200rpm. There is 14-18hp more with the Honda intake manifold after 7200rpm. From 3000rpm to 7200rpm, it looks like the Honda intake manifold performed similar to the cyclone intake. At some points in the down low and in the midrange, the Honda intake some what edged pass the cyclone manifold. The cyclone butterfly instantly opened at 3000rpm since the vacuum line was ran directly to the actuator.
This graph has the correlating tq readings of the two hp readings in the graph above.
Notice how the Honda intake manifold made more tq after 7200rpm and down low too.
Notice tq advantage from 4000rpm to 5000rpm for the Honda intake manifold. The cyclone intake manifold has a little more tq around 5200-6600rpm.
This graph is with the Honda intake manifold. The turbo spiked to 25psi and bounce between 23-24psi. The weak 10-12psi wastegate spring was causing a lot of unstable boost during the Dyno session. I believe it makes the curves look wavy. My friend really need to have at least a 16-18psi wastegate spring. Hope get one soon. You can hear the turbo flutter during the pulls after 16psi. As you can see, the Honda intake manifold will support 500+hp and makes pretty good tq too. This was out last run. We ran out of fuel for some reason.
2.4l 7 bolt block
BC 272/272 combo
Cometic head gasket
Kings bearings
Bs elimination
3" exhaust
2g unhack maf
1200cc RC injectors
Unicorn blood (E85)
