Deeracer19
- 1
- Dec 15, 2021
Edgewood,
Maryland
Let’s start by saying I’ve read a lot of forums from DSM.
So far I’ve replaced everything listed OEM.
Crankshaft position sensor
Camshaft position sensor
MPI/MFI Relay
Starter Relay
Ignition coil pack
Ignition wires
Spark plugs
Battery
All fuses working
All grounds clean except (location 1.)
Fuel system (injectors, filter, pump.)
Yes the pump turns on.
Ignition switch
Timing is spot on.
No CEL’s
PTU
Coolant temperature sensor & gauge
Tries to start but backfires pressure to PCV blowing air out and air intake starts smoking I’m assuming from flooding.
Turning the ignition to start it clicks, cranking it does nothing but after I stop you can hear the fuel pump.
I’m suspecting something going on with the ECU. or some sort of short I’m not finding here.
MPI/MFI Relay
Starter Relay
Ignition coil pack
Ignition wires
Spark plugs
Battery
All fuses working
Ignition switch
Timing is spot on.
No CEL’s
PTU
