gsx4357
- 103
- 0
- Sep 26, 2010
maricopa,
Arizona
hey guys im have a problem with my clutch...i just changed the master and slave cylinder in it and bled everything through and adjusted it. i took the car for a drive and it was fine. then i turn it off and 5 minutes later i turn it on and try again and it wont go into gear again. i adjusted it by tightening it until i couldnt depress the slave anymore and then loosened it by a half a turn. i bled it first at the master cylinder and then when there wasnt anymore air coming through i bled it and the slave until it was only fluid. bottom line is...it will go into gear sometimes when you make some kind of adjustment...other than that it wont into gear at all. any ideas?
