tay97gst
- 476
- 32
- Dec 20, 2011
Plaistow,
New_Hampshire
Well like the title says I'm trying to properly adjust my biss using ECMlink but I'm having a problem I couldn't find with searching. When I start my car and let it idle until normal operating temp, ISCposition will slowly drop down to zero, and no adjustments made to the biss screw will change it's reading. While doing this I did not ground the diagnostics pin because I've read that you should and shouldn't so I'm not sure which is right. It may also help to know that I have replaced the oring in the biss, checked the isc using a voltmeter (was 29-30 for all), and am simulating idle switch in link. Not sure what's going on here. Could it be a bad ISC even though the resistance checked out? I have a spare one I could throw in. I have the ability to post a log showing it drop if need be. Let me know if you have any opinions on what's going on
