Dstarperformance01
- 880
- 172
- Mar 5, 2016
Mustang,
Oklahoma
Has anyone used AGP for BB turbo service? I’d love to hear ALL stories as I’m considering using them on my unit that just started seeping oil into turbine housing. Thank you
Note: This feature currently requires accessing the site using the built-in Safari browser.
Here’s my PCV(no baffles in VC) and drain set up.Assuming it's a GT unit, Garrett doesn't sell parts individually so if they're replacing anything more than just the sealing rings themselves then who knows what you're getting...but if they stand behind it should anything come apart, that's on them.
I can do a sealing ring replacement to these units but I don't really advertise it because I don't want the liability of working on ball bearing turbos...but if the bearing sleeve is worn at all, the CHRA would need to replaced, and if the bearing sleeve isn't worn then whatever is causing the turbine sealing ring leakage will just do it again in a short period of time (usually a drain or PCV issue).
Here’s a pic of it installed.PCV looks good but that manifold sure seems to place the turbo awfully low unless it's just an illusion.
