Please Support STM Tuned
4g63t conversion issues
Lano91
Mar 31, 2019
osl, Europe
Hello, so some background before we get started. I have 1997 mitsubishi eclipse 4g63 nt, euro.
Recently swapped in a 1999 gst engine and 1999 gst black box ecu.
I decieded to modify the old nt harness to accomodate turbo applications. So far i have added the MAP sensor, injector resistor, boost gauge.
Issue now is that the car wont start. It will not crank. I have tested the starter and it works. Fuel pump works, however injectors are not spraying in any fuel? this is with the 1999 black box ECU.
When i plug in the 1997 nt ecu, the starter works, the injectors work but the fuel pump does not.
Any help please? im losing my mind....
