Please Support Morrison Fabrications
Please Support STM Tuned
Resolved 2G no ignition, no accesories, no CEL, all fuses good try two ecus still no power
danielbo91
321
Dec 19, 2010
fort worth, Texas
Going home from work , my car lost all power it would start by it self all the dash light came on check engine every light on the dash turbo timer was reseting, and then finally everything went off loss all power to the gauges I have No cel light , non of the dash light come on, also my accessories don't work ethier radio , windows don't go down or up. What works are doors locks, head lights work illumitions light for the dash work . I change my ignition switch still nothing , try different ecu still nothing, I completely removed the turbo timer still nothing, I also check all fuses none are blown , also fuel pump dosent come on ethier , battery is good also I check the wiring to see anything bad everthing looks normal what to look next because I'm lost . What relays should i check next and where are they located so I can get my car fix thanks.
I still can't figured what's causing my car not start , and get any power , starter, fuel pump,gauges,accessories radio,windows , no cel light also I'm lost tried two ecus still nothing .
Solution
Man Is been years since I had that car nice way bring me back bad memory's from that car, it was the fuse box wiring harness I end up replacing the fuse box hardness and engine bay harness may want to check that
Sounds like it might be a lost ground connection. I would start there first and check all of the grounds in engine bay and console. Kinda odd some electric components work but not the others
Sounds like the 100A fuse located in the fuse block under the hood opened up on you. It's the one that is actually bolted in the relay block with 10mm bolts on each side-it's not a plug-in fuse as with the others. You will have juice to some ares but not to some others-by what you're mentioning.
It may look good, but one leg cold have opened up that you can't see until you take it out and check with a VOM ... I've been there and done that as well.
Ok guys I still need help figuring out what's wrong with my gsx as to why non my electronics work battery has 12.33 volts , nothing works just head lights dash lights interior light and stock alarm works I really need to fix this soon is there a relay or something that could be bad all fuses are good , can someone help me please here a pic with the key on and nothing comes up
Check your wiring to your wideband/gauges. Also check for any loose grounds in the engine bay, make sure your negative terminal battery cable is grounded properly. There is a ground on the starter as well, not sure if that would have something to do with it. It sounds like a wiring issue for sure.
Try all that what you you told me already I'm starting to think I need to pull the harness out and check the wires , battery has plenty of juice 12.33 volts , but only that's is working is stock alarm, headlights ,interior lights dash lights emergency turn signals but that's nothing is getting power is the fuse or relay that could be causing this problem
So no one can help me what can it be that I have no power everywhere
The first thing to do is remove battery cables, both ends of each, and clean them with a wire brush and sandpaper. Also clean whatever they attach to (battery post, body, engine, bolt). Then tighten them back up securely. You should have one large cable going from battery negative to body and a separate cable going from battery negative to a starter mounting bolt on bell housing.
Might wanna check the taillight relay. I know several circuits are powered through it. I had a problem where my headlights worked, but no other exterior lights worked. Ended up being the taillight relay. I'd check that and grab an electrical manual and see what relays and components are involved in the circuit. 9 times out of 10 it's a fuse,relay ,or component. Not the harness.
Solution
