Lolmooses
- 73
- 2
- May 26, 2014
portland,
Maine
1). Any boost, vac, or exhaust leaks?
Boost leak tested 5psi above your max boost with no leaks?
No leaks
2). Verified mechanical timing?
Spot on
3). Verified base timing?
5* BTDC with a timing light
4). Ignition system
COP or Stock Coil: Stock
Wire brand and Age: NGK 1 year old
Spark Plug brand, type and Gap: NGK BPR7ES 0.28"
5). Motor health (Compression Test)
Cylinder 1:175
Cylinder 2:175
Cylinder 3:175
Cylinder 4:170
6). Performed basic throttle body adjustments?
Idle Switch:Yes
Throttle Cable:Yes
TPS:0.63v
BISS:Yes
7). Compression ratio
7.8:1
8). Any known bad sensors or brittle wiring?
No
9). Any DTC/CEL codes?
No
10). Electrical system
Car off (not running):12.6v
Car running:13.5v-14.5v
Base Fuel Pressure:37 PSI
Injector Size (cc/min):780 PTE
Sensor Brand:Innovate MTX-L
Calibration Date: Less than a month ago
13). Type of fuel
Type:91
Percent of Ethanol: 10%
14). Watched ECMlink how-to videos?
Yes
I can't run any positive timing whatsoever without getting knock. I uploaded two different pulls just to give you guys some data. Adding fuel seems to make no difference when adding timing. What could I do to get some positive timing without knock outside of higher octane fuel?I have an intercooler coming to address my IATs with the stock one. I also cannot get my 14b to go under 20 psi once it hits around 5000 RPM, so lowering boost is not really something that has helped. I'm fairly new to all this still, so I'm open to any suggestions.
No leaks
Spot on
4). Ignition system
Cylinder 1:175
Cylinder 2:175
Cylinder 3:175
Cylinder 4:170
Idle Switch:Yes
Throttle Cable:Yes
TPS:0.63v
BISS:Yes
7.8:1
No
No
13). Type of fuel
Type:91
Yes
