mini zilo
- 783
- 19
- Jul 17, 2006
Chicago,
Illinois
I just finished my manual shift knob installation on my automatic. Here's the thread...
http://dsmtuners.com/forums/showthread.php?t=253305
I know all the people that wanted to do it were wondering how to relocate the overdrive switch.
You need a TWO-way toggle switch, that has 3 ports on the back. I used this one from radioshack...
http://www.radioshack.com/product/index.jsp?productId=2062495&cp=&pg=2&sr=1&origkw=toggle+switch&kw=toggle+switch&parentPage=search
Now, in order to get to the wires you need, you need to cut the wire from the harness (near the shifter base) that goes to the stock o/d switch. Once cut you will see 3 wires, one black, one red, and one yellow. Wire them to the switch like this...
I mounted the switch in place of the cigarette lighter because I never use it, and it's easy to get to. I actually like it better here.
Hope this helped.
Hope this helped.
