Please Support RTM Racing
Street Build Techboy's 99 4G63
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
16g
Drivetrain
AWD
Build Type
  1. Street
HRC S16G turbo, HRC FMIC & hardpipes, FP manifold, FP oil return tube, port & polished 2G intake manifold machine matched to 1G TB, 650 FIC injectors, Custom-made JMF Downpipe, STM 3" cat back exhaust, JMF spark plug cover, JMF Coolant overflow bottle, JMF polished coolant pipes, Mishimoto aluminum radiator, fan shroud & high flow fans, Prothane Urethane motor mounts.
Mods-Engine
Stock bottom end w/ machined head - 1mm O/S valves installed. Held together w/ ARP Head studs, BSEK, Gates Racing Timing belt.
Mods-EMS & Logging
Apexi SAFC-II & AEM WIdeband for tuning and monitoring. Autometer Phantom oil pressure & boost gauges.
Mods-Drivetrain
Short shifter & solid shifter cable bushings. ACT Lightened flywheel w/ Act 2600 & Pressure Plate.
Lowered on Koni Adjustables w/ Eibach Prokits. Aftermarket front and rear sway bars/strut bars. Rolling on Hankook Ventus RS-3's.
Parts Wishlist
JMF street sheet metal intake, ECMLink V3.
Background
I started my journey with DSM's in summer of 2000 after purchasing a 99 GS Anniversary Edition off the lot. I turbo-charged that car in short order and drove it for roughly 5 years until I decided to make the jump to the 4G63 platform. I was searching for an X13 GSX, but came up short and settled on an X13 GST. Eventually I swapped the car to the GSX using a donor car which I thoroughly documented here on the board. Future plans involve finally installing my ECM Link and buying a bigger turbo and more robust fuel system.
1/8 Mile E/T
9.228
1/8 Mile MPH
83.46
Timeslip Details
Numidia Dragway, PA. May 2013. Rear interior of car removed w/ slicks upfront that didn't help with traction near as much as I was hoping it would.
Dyno HP
305 whp
294.6 lb/ft
Dyno Type
DynoJet
Dyno Sheet Photo Link
Dyno Video Link
Watch Video
Dyno Shop Name
R/T Tuning, PA
Dyno Session Details
94 Octane Pump gas. Photo link is of the only dyno sheet I can find right now. We made a few minor fuel and boost adjustments after the sheet linked and the car made just north of 300. Video link is of an older dyno session several years before when the car had less modifications.
techboy
Comments
2
Rating
5.00 star(s) 1 ratings
More from techboy
Share this Vehicle
