- Year
- 1990
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- 2g mas air, 2.5 intake pipe, front mount intercooler, supra TT fuel pump, hallman boost controller, adjustable fuel pressure regulator, 550 cc injector, big 16g, 3in exhaust, kevlar timing belt, oil cooler, accell spark plug wires, ngk plugs(bpr9es), zex nitrous kit
- Mods-Engine
- 3rd gen lifters, balancing shafts removed, rebuilt short block, dual valve springs, arp head studs
- Mods-EMS & Logging
- apexi afc II, eprom ecu stage III, wideband o2, boost guage
- Mods-Drivetrain
- jackstransmission.com evoIII close ratio gear clusters, 4-spider diff ,stage 2spec clutch, slave cylinder extention rod, 3 bolt rear end
- Mods-Handling
- stock and woreout strut tower bar front and rear
- Parts Wishlist
- 4-bolt rear
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
